1998 Dodge Ram 2500 V10 pcm help
Old Feb 20, 2013 | 04:47 PM
flynnzo77's Avatar
flynnzo77
Default 1998 Dodge Ram 2500 V10 pcm help
hey whats up? new to the forum and ive gotten some good info so hear i am trying to see if anyone could help me out. i have 1998 dodge ram 2500 v10 gas truck and i am having problems with the pcm regulating power but i dont think its the pcm because all my gauges work and my truck starts right up and drives fine other than its in limp mode. the problem started when i was changing the alternater and i hit the two leads in the back with a soket...figures i can hit that but not the lottery but anyway i seen a spark so i know i shorted out something. i checked all fuses in the truck and under the hood and thats as far as i can go so if anyone could help i would greatly appreciate it...thanks!
Old Feb 20, 2013 | 05:11 PM
merc225hp's Avatar
merc225hp
You could try dis-connecting the batt neg side this will reset the pcm. Other than that a new pcm is in order as it controls the voltage.
Old Feb 20, 2013 | 05:54 PM
flynnzo77's Avatar
flynnzo77
ya ive done that and had no luck. so even with all the gauges working and the truck starting u think its a bad pcm? someone told me to check the 5v power supply for the pcm but i dont know what harness or number to check, u wouldnt happen to know the lay out for the pcm harness numbers?
Old Feb 20, 2013 | 06:03 PM
merc225hp's Avatar
merc225hp
Sorry no I don't. Not sure if it will help you as your year truck is not listed but the FSM's the 97 and 2001 can be Dl from here.
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Feb 20, 2013 | 07:39 PM
flynnzo77's Avatar
flynnzo77
hey thanks for the tip, i just hope i can find the problem...going on a month, i should just bite the bullet and buy a pcm...just so much money if its not the case. but u live and u learn...thanks again for your help!!
Old Feb 20, 2013 | 07:51 PM
merc225hp's Avatar
merc225hp
Not a problem hope it helped somewhat. Using a DVM what's showing at the batt (volts) with the truck running?
Old Feb 20, 2013 | 08:04 PM
flynnzo77's Avatar
flynnzo77
ya the 2001 works, it even had my 8.0 v10 engine. looks like ill be doing some testing with my meter tomorrow, ill keep u posted and let u know how i make out but i have a feeling its the pcm regulater...so it sounds like a new pcm
Old Feb 20, 2013 | 08:07 PM
merc225hp's Avatar
merc225hp
I was just out looking for a Mopar performance pcm for you, but alas no such animal for your year truck
Old Feb 20, 2013 | 10:54 PM
flynnzo77's Avatar
flynnzo77
what would a performance pcm do over ride the pcm somehow?
Old Feb 20, 2013 | 11:04 PM
merc225hp's Avatar
merc225hp
No it's a complete replacement pcm made by Mopar, I found them for a 94-95 V10 truck and a newer srt10 truck but not for your year truck.
Have a look about 3/4 of the way down the page. http://www.mopartsracing.com/parts/ram.html
