shift kit
Old Feb 21, 2013 | 07:33 PM
Reddnek's Avatar
Reddnek
Default shift kit
so a few months ago i put a newer trans in my truck my buddy sold me, said he had it built with a shift kit, but im not having any luck about finding out if there is a special band adjustment procedure... anyone know if there is one or if its the standard adjustment.
Old Feb 21, 2013 | 07:36 PM
gdstock's Avatar
gdstock
Standard adjustment. Shift kit basically consists of spools and springs for valve body.
Old Feb 21, 2013 | 08:28 PM
Reddnek's Avatar
Reddnek
so another question i have is when i put the trans in i drove it around for a while and then did a service on it and adjusted the bands on it like the manual said and then after the it didnt shift as harsh as it did before more like a new plain factory one.... is that something i did with the adjustment? and how often should line pressure be adjusted, and does it have have any benefits or negatives if its moved around?
Old Feb 21, 2013 | 08:40 PM
gdstock's Avatar
gdstock
If you have gauges, you can see what you are adjusting. Only one adjustment for pressure (without modifying spools and ports). Manual indicates how much and which way to turn screw.
