Help!! No start 98 dodge ram 1500 5.9l
Old Feb 24, 2013 | 09:40 PM
  #21
gdstock's Avatar
gdstock
ABS and brake light is something separate. Possibly the RAWL sensor on pumpkin if your brakes are working correctly.
Old Feb 25, 2013 | 12:43 PM
  #22
wolfpack360's Avatar
wolfpack360
Yea thats what I thought but replaced it yesterday and lights are still on speedo is working fine and brakes work fine.I have inspection coming up so trying to get all the lights off.
Old Feb 25, 2013 | 01:42 PM
  #23
You have two, or four wheel ABS? Check the front hubs, if you have wires there, you have 4wal, and will need to have it scanned for abs codes.
Old Feb 25, 2013 | 02:15 PM
  #24
wolfpack360
I just have rear abs is there still a sensor on the front hubs?
Old Feb 26, 2013 | 10:47 AM
  #25
Nope. If you have RWAL, no sensors on the front.
Old Feb 26, 2013 | 12:31 PM
  #26
wolfpack360
I am gettin a guy to look at it tommorrow so I'll report back with the problem thanks yall! Not taking it back to that place that tried to rip me off big time guy said 50 bucks for ignition timing abs/parking brake light and fixing my horn so not a bad deal.
Old Feb 27, 2013 | 07:15 PM
  #27
wolfpack360
So the guy just checked out my truck and helped me install the horn and looked at the abs/parking light issue. Apparently somehow the abs module "forgot" the tire size and differential for some reason. Think somehow that place I took it to could have maybe done something. Anyways thanks again for all the help yall!
Old Apr 1, 2013 | 11:59 PM
  #28
Ramthis98's Avatar
Ramthis98
I have a bog problem too, my 98 dodge ram cranks buy no spark is it my coil or something else.. Any advise would be great thankx!!
Old Apr 2, 2013 | 12:01 AM
  #29
Ramthis98's Avatar
Ramthis98
I have a same problem, my 98 dodge ram cranks but no spark from wire wat is the problem plz help me thankx
Old Apr 2, 2013 | 10:25 AM
  #30
Verify power at the coil. (it's only there for a few seconds, so, some help will be in order.)
Check to see if PCM is firing coil. (test light on ground wire for coil, to battery. light should blink while cranking)
