Over-tightened bolts
Old Feb 22, 2013 | 12:41 AM
TheBigRedTruck's Avatar
TheBigRedTruck
Default Over-tightened bolts
I started tightening the intake manifold bolts to 144 lbs-ft instead of 12 lbs-ft. I backed them out quickly and did them all at 12 lbs-ft. Is i possible i crushed the gasket? It was only for 5 minutes until I realized. Truck idles smooth with no roughness or anything. Can't take it for a drive because my throttle valve cable broke.
Old Feb 22, 2013 | 04:52 AM
msheridan's Avatar
msheridan
Check your vacuum pressure, and keep an eye on your coolant level.
Old Feb 22, 2013 | 11:14 AM
And watch your oil for evidence of coolant intrusion.....
Old Feb 22, 2013 | 11:24 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I think you're ok, but I'd get another set of bolts as they are not expensive.
You definitely over did the gaskets b/t the IM and the block!
Let me ask you this...how many of the bolts did you do this to?
Old Feb 22, 2013 | 11:26 AM
Make sure the end seals didn't get squeezed out as well..... (makes for a nasty oil leak.)
Old Feb 22, 2013 | 12:36 PM
TheBigRedTruck
did it to 2 bolts. took it for a drive and everything seems fine. no leaks so far externally. hopefully got lucky
Old Feb 23, 2013 | 03:46 AM
dhvaughan's Avatar
dhvaughan
monitor for coolant loss, white smoke from exhaust, water in oil, or oil leaks/oil loss.
if none of that you are fine. leave it be.
Old Feb 23, 2013 | 10:19 AM
Jr. Mechanic's Avatar
Jr. Mechanic
There's no way the intake bolts could take 144 ft/lbs without shearing, so what did you really torque them to?
Old Feb 23, 2013 | 10:45 AM
Sooper's Avatar
Sooper
I agree. The bolts would have sheared and depending on which bolt you would have cracked the intake too.
Old Feb 23, 2013 | 11:14 AM
TheBigRedTruck
they probably went to 30 lbs-ft.
