Last edit by: IB Advertising
Browse all: Steering & Suspension
- Dodge Ram 2nd Gen How to Replace Front and Rear Shocks
Step by step instructions for the do-it-yourself repairs.
Shock Replacement
I haven't actually done much with the shocks yet, as soon as I mentioned the broken shackles the guys here said those should be taken care of first. If I did I'd probably buy the $25 Monroe Monro-Matics, since they're in stock around here.
What kind of tools do you need? Looked like they're just held on by your average bolt to me.
You can do the whole thing with hand tools. The shock bolts go into trap nuts that have handles on them so they keep from spinning while you turn the bolt.
BTW, when you're doing this make sure that your shock bolt threads aren't worn down to a smooth shaft. This will cause thumping and rattling. If the threads are fine you can reuse the bolts.
That's the great thing about the 4x4 trucks, no need for jacks. You can get under it and replace all four shocks with it sitting at ride height.
I always recommend removing the spare tire which makes getting to the rear upper bolts easy.
The front shocks will require the shock cage to be removed, and on mine on the driver's side I had to unbolt the master and move it sideways just to get the old shock out. The one one will drop in and you can get it seated, and bolt the cage back down before you cut the retaining strap off of the shock.
