CSF 2969 All Aluminum Radiator
Old May 27, 2013 | 08:22 PM
AtomicDog's Avatar
AtomicDog
Yes, this is the same radiator I installed when I did my engine swap a couple of years ago. No plastic tanks to go bad! Keeps my engine temp steady and its a bolt-in swap.
Old May 27, 2013 | 09:51 PM
Wombat Ranger's Avatar
Wombat Ranger
I have one in my '95 now, I like it much better than the factory crap.
Old May 28, 2013 | 03:15 PM
guzman's Avatar
guzman
Default Radiator
I also installed one of these aluminum radiators BEFORE my factory one went to hell. Great fit and very well made.
Old May 29, 2013 | 01:34 PM
Arde's Avatar
Arde
I've been checking E-Bay, Amazon, and even went to the CSF site and checked their catalog. Everything I've checked so far specifies a plastic tank for the CSF 2969. Doesn't look like CSF makes anything but plastic tank radiators anymore for Rams.
Old May 29, 2013 | 03:32 PM
billcart's Avatar
billcart
http://www.radiatorexpress.com/produ...aia_id=1354159
Old May 29, 2013 | 09:00 PM
dhvaughan's Avatar
dhvaughan
http://www.ebay.com/itm/CSF-2969-Radiator-/321122381119?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ac462ad3f&vxp=mtr
If anyone wants one, you better get it now. Arde is correct, this one has been discontinued and replaced by the crappy plastic tank.
$194, free shipping, no tax.
all aluminum.
from http://www.csfradiators.com/csf_catalog/#
Radiator No. 2969
Core Size 31-5/8 x 19-5/16 x 1-1/4
Tank Size Inlet 19-7/8 x 2-1/8
Outlet 19-7/8 x 2-1/8
Hose Fittings Top 1-1/2 Left
Bottom 1-3/4 Right
No of Rows 1
Oil Cooler 14-7/16 in.
Tech. Note Strengthened All Aluminum tanks & core.
Remark Will be superseded by #3359 after existing stocks are depleted.
Radiator No. 3359
Bottom 1-3/4 Right
No of Rows 1
Oil Cooler 11-13/16 in. Plate type
Tech. Note O.E.M. Style Plastic Tanks and Aluminum core. Manufactured with steel crimps to strengthen radiator by 40% Over O.E.
Remark
Old May 30, 2013 | 09:34 AM
Wombat Ranger
Hope I dont get in a front end collision again...
Old May 30, 2013 | 05:10 PM
SparkMasterB's Avatar
SparkMasterB
This is frustrating. Might get this done on my other ram now (or keep it as a backup) while the 2969 is still $200 shipped.
The new 3359 does state with Steel crimped to make it stronger, but I have no idea how much stronger that will make it. Crimped anything is a bad design, period. If you live in an area with bad (or dirt) roads, things fatigue quickly. I'm all for making things more efficiently/less expensive but its not always the best idea. Having a radiator 'wear out' is not a routine maintenance item. My family has had vehicles with 200k+ miles on them with no issues till around the late 90's, early 00 models with things you wouldn't expect to wear out, like a radiator.
The OE radiators seem to last about 10-12 years in my experience (a few failing around 100k miles, one at 200k) in the same manner. The endcaps start to leak.
Old May 30, 2013 | 07:10 PM
AtomicDog's Avatar
AtomicDog
No way a radiator with plastic tanks crimped onto an aluminum core is going to outlast an all-aluminum radiator, as long as the all-aluminum unit is welded (like the CSF unit) and not put together with epoxy. The welded all-aluminum radiator can be repaired, if needed. I agree with you that so many items on cars these days are made with obsolesence in mind. At least with forums like this, we can share information to keep these vehicles going longer and stronger.
Old May 30, 2013 | 07:47 PM
guzman's Avatar
guzman
Default Csf
Ebay still has them listed under CSF 2969 #370787867308 for $204.68 shipped.
Glad I bought mine when I did since they are to be discontinued...Too bad. :-(
