reverse light problems...
Old 02-26-2013, 09:45 PM
keith97's Avatar
keith97
keith97 is offline
Default reverse light problems...
Anybody ever have trouble with their reverse lights popping fuses? I have replaced the bulbs checked for loose or bare wires.. Every time i put new fuse in i get about 4 uses of the lights and then the fusr blows.. anyone got any ideas???
Old 02-26-2013, 10:17 PM
kejobe's Avatar
kejobe
kejobe is offline
Has to be a short somewhere. If it works sometimes before blowing, Id be looking around the steering column.
Old 02-26-2013, 10:54 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
do you have the 7 pin trailer harness with the backup light wired to one pin. if so, see if you can unplug that harness and see if it fixes the problem.
Old 10-09-2013, 10:28 PM
loadtowr's Avatar
loadtowr
loadtowr is offline
Where is the fuse you speak of. I can't find mine and I think I blew it while wiring up my trailer plug.
Old 10-10-2013, 10:15 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
What year is your truck? We have a selection of service manuals available in the faq section.
Old 10-10-2013, 10:40 AM
jkeaton is offline
In the fuse box on the drivers side of the dash, at least it was on my 97. It would help to know what vehicle you are referring to.
Old 10-11-2013, 11:41 AM
loadtowr's Avatar
loadtowr
loadtowr is offline
1998.5 diesel 4x4
I was installing a new 7 wire plug. I found the purple wire (I think it was purple but test as reverse) above the spare tire in the harness. I spliced into the wire with a soldered connection. When done soldering I could not get test light or brake light.
Old 10-11-2013, 11:44 AM
HeyYou is offline
Did it blow the fuse?
Old 10-11-2013, 12:10 PM
97r/tram's Avatar
97r/tram
97r/tram is offline
Mine flicker and my buddys 98 don't work at all. Seems common
Old 10-11-2013, 02:10 PM
loadtowr's Avatar
loadtowr
loadtowr is offline
I scratched the fuse terminals up a bit and it seems to be working
Thanks
Quick Reply: reverse light problems...
