Lower Radiator Hose
Old Mar 3, 2013 | 08:09 PM
TheBigRedTruck's Avatar
TheBigRedTruck
I did, and it holds 13lbs. No leaks except in the old radiator. Before the leak happened I was holding the same amount of coolant for over 3 months.
Old Mar 4, 2013 | 10:58 AM
coldsteel5's Avatar
coldsteel5
What kind of clamp are you using?
Lol...don't even go there.....
Old Mar 4, 2013 | 04:38 PM
Big Joe C's Avatar
Big Joe C
I'm havin the same problem with my 01 5.2. The water pump pulley bearing went out...then took out the water pump and it just puked out coolent everywhere. I put on the new water pump and new top hose, bottom hose seemed good. I've checked many of times and the water pump is dry where it mounts. But I'm gettin coolent dripping down from the top of the bottom hose...then it runs down that and gets all over the steering bars. I even put on the screw type raditator clamp on the top of that hose and torqued it done and its still leaking somehwere. I still can't firgure out where its comming from. Oh and it leaks even more when the heat is on. Ughh it's driving me crazy!
Old Mar 4, 2013 | 08:21 PM
gdstock's Avatar
gdstock
Check the bypass hose on water pump as well. It is right there, cleverly covered up....but is prone to leaking after time.
Old Mar 5, 2013 | 12:28 AM
TheBigRedTruck
I have ALL new hoses and clamps. After coming home i tightened the clamp more and it stopped. What puzzles me is why it's coming loses over time.
Old Mar 5, 2013 | 12:29 AM
TheBigRedTruck
coming lose***
