Want to go faster than the 5.7 hemi
Old 03-04-2013, 09:43 AM
Sooper's Avatar
Sooper
Sooper is offline
My point is that the whole question is silly. "OMG my friend has a newer and more powerful truck and I want to beat him." I wish my biggest problem was if I should spend a couple grand to make a 20 year old truck faster than a 4 year old truck for bragging rights. LOL.
Old 03-04-2013, 09:57 AM
Blackbox19's Avatar
Blackbox19
Blackbox19 is offline
Throw some gears in the back, you may not beat him in the 1/2 mile with lower gears. But off the line and 1/4 miles you will hand it to him.
I had a cherokee with 4.56 gears, and buddy has a mustang GT. I would stick some smaller tires(30s) on the cherokee (has 35s) and I would be gone. Take off like a rocket ship
Old 03-04-2013, 11:05 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
read the posts he already said he gets him off the line
to the po buy the 2nd gen that had the hemi set up replace the bum engine and win in a second gen with out dumping 3-5 grand (depending on your area)
Old 03-04-2013, 11:10 AM
Blackbox19's Avatar
Blackbox19
Off line AND 1/4 mile with better gears... But all this seems silly. trucks are trucks. Not go fast machines.
Old 03-04-2013, 11:34 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Originally Posted by redneck_ram
the latest hemis have what, 390 at the crank? the 360 im building, should be throwing down close to 380 at the crank. i didnt touch the bottom end either. cam, 1.7 rr's, better heads, mopar m1, lt headers with appropriate exhaust, 50mm throttle body, and a hemifever tune.
youre looking at close to 3k in parts, and another 500-1k in small items.
There used to be a guy on here that threw a bunch of money at his truck in the short time he was here and went to a shop with a dyno a few times while he was at it. He gained something like 70hp just by replacing the heads. I could see your combo putting out near 270ish once it gets to the ground.
Since you're going to be doing what you're doing with the truck already then you might want to think about throwing an off road y-pipe on your list if it isn't already on it with the "appropriate exhaust", it's been said on here that they make a big difference in exhaust flow.
Old 03-04-2013, 11:44 AM
merc225hp's Avatar
merc225hp
merc225hp is offline
Just putting on a set of eddy aluminum heads and a small cam will get you 130hp gain add some more parts and hp and tq numbers will go up even farther. These motors respond well to mods, have a very strong lower end most parts on/in it will support up to 500hp even the crappy heads with work will go that high. All it takes is cash and the right combo of parts and big hp/tq numbers can be reached. As for putting a hemi in a second gen truck not me, the Hemi's have there own share of problems.
How to add 129hp to a Magnum motor.
http://www.hotrod.com/techarticles/e...e/viewall.html
Old 03-04-2013, 01:33 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
i have the pacesetter longtubes with the pacesetter y pipe that goes with them. running a 3" single exhaust.
Old 03-04-2013, 04:54 PM
chromed95's Avatar
chromed95
chromed95 is offline
Originally Posted by Scooter78
Come on now guys... Lol... It can happen
You will need to really beef up that 5.9 in your rebuild to hang in there though. The typical hot rod stuff... better heads, higher compression pistons, better rockers, cam.... Then of coarse you will need a retune on your PCM. I think Hemifever is the guy to talk to on that. From what I have heard, he can make your PCM run most any parameters you want.
Isn't the hemifever tune only '96 and newer? His is '94. I could have this mixed up with something else though....
Old 03-04-2013, 04:56 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Trucks are for hauling cargo, not for hauling ***.
Old 03-04-2013, 05:02 PM
guzman's Avatar
guzman
guzman is offline
Default Trucks
Its nice to have a truck that performs well but this ^^^^^ is correct.
Quick Reply: Want to go faster than the 5.7 hemi
