Low beams wont work at all : /
Old Mar 4, 2013 | 01:08 PM
RamIt4792's Avatar
RamIt4792
Default Low beams wont work at all : /
Just me again with another issue that popped up. The other day my headlights were flickering so i popped the hood and removed the wire for the bypass for the fog lights so i could have fog lights on with brights and put the relay back in and then it stopped flickering and worked. Then today I go to to put on the headlights and nothing. My yellow lights work and if i hold the brights they work too. Any idea what I should do? Ive checked fuses and relays not sure where the ground is for headlights tho.
Old Mar 4, 2013 | 01:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Start by removing the headlight switch itself, unplug it and check it and the plug for burning or melting.
Old Mar 4, 2013 | 06:07 PM
RamIt4792's Avatar
RamIt4792
Did that found it was burned on the wire harness above the number 11
Old Mar 5, 2013 | 06:22 AM
zman17's Avatar
zman17
Well you know what to do next.
Old Mar 5, 2013 | 04:19 PM
RamIt4792's Avatar
RamIt4792
New harness in and works great just got a new switch to for the heck of it lol. Why did it burn like this tho?
Old Mar 5, 2013 | 04:26 PM
zman17's Avatar
zman17
It's a common issue with Rams. There is even a TSB from dodge dealing with it. Although the TSB only relates to certain years and the 3500 trucks. Newer trucks even have a heat sync built in to the headlight switch.
Old Mar 5, 2013 | 11:15 PM
gdstock's Avatar
gdstock
Putting headlights on relays will help prevent the problem by ruducing the current draw through the switch.
