Third Brake Lights
Old Mar 5, 2013 | 05:02 PM
TheBigRedTruck's Avatar
TheBigRedTruck
Default Third Brake Lights
Just found out today that my third brake lights no longer work. I removed the radio and cut the wiring harness. I found out that the third brake lights are wired together. My question is do I need the radio plugged back in or just the harness?
Old Mar 5, 2013 | 05:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I may be wrong, but the heck does the radio have to do with the brake lights?
Old Mar 5, 2013 | 05:08 PM
TheBigRedTruck
I thought it was crazy too. On the third brake light it says "With Cargo". I don't know of any other reason why the lights wouldn't work.
Old Mar 5, 2013 | 05:14 PM
zman17's Avatar
zman17
I suggest you get a Haynes manual since you have a 95. The schematics for tracing wires are rather good for your year. And why would you just cut the wires anyway?
Old Mar 5, 2013 | 05:17 PM
Have you checked your fuses? If you just *****-nilly cut the wires you probably shorted something out and blew a fuse.
Old Mar 5, 2013 | 05:21 PM
TheBigRedTruck
i have the haynes manual and am trying to trace the wires. Fuses look fine. I cut the harness because i was supposed to install an aftermarket radio but didn't.
Old Mar 5, 2013 | 05:45 PM
TheBigRedTruck
changed the I.O.D. fuse. now the third brake light works only when i press the brake pedal, but not when my low beams or headlights are on. Maybe that's the way it is.
Old Mar 5, 2013 | 07:13 PM
Spillage's Avatar
Spillage
Third "Brake" Light is only with the brakes... the Cargo Lights are at the end of the instrument light dimmer (rotation of the headlight switch).
Old Mar 5, 2013 | 08:39 PM
Third BRAKE light only works when you are pressing the brake. It's not a running light that comes on with your headlights.
Old Mar 5, 2013 | 11:18 PM
gdstock's Avatar
gdstock
Snd for future reference, about $10 buys an adapter for most vehicles that adapt factory wiring connector to after market radio units. Eliminates cutting up wiring (and creating future problems).
