Help please
Old Mar 6, 2013 | 01:32 AM
96dodge4x4's Avatar
96dodge4x4
New Member
Default Help please
I have a 96 dodge ram 4x4 and I had a bad coolant leak I changed the w/p and t stat and head gaskets my upper radiator house spouted a leak any suggestions on what happened?
Old Mar 6, 2013 | 04:37 AM
guzman's Avatar
guzman
Default ???
Was it a brand new hose? Where did it spring a leak....end....middle....under clamp???
Old Mar 6, 2013 | 07:52 AM
How old was the hose? Maybe you didnt get the clamp tight after reassembly. Maybe you need a new hose. Maybe you cut it and put a hole in it. Hoses leak for many reasons. Kinda hard to tell without a picture.
Old Mar 6, 2013 | 08:16 AM
Scooter78's Avatar
Scooter78
I would just throw a new hose on it and call it a day. Its not an expensive or difficult piece to replace and they generally last for a long time, so I would not be too worried about why it failed. Its not likely to happen again anytime soon.
Old Mar 6, 2013 | 10:58 AM
gdstock's Avatar
gdstock
Why would you change head gaskets for a coolant leak? Did you have a prior problem sucha as severe overheating that caused the head gaskets to blow?
Old Mar 6, 2013 | 11:02 AM
zman17's Avatar
zman17
Retired Moderator - RIP
We don't even know which end of those is leaking.
