growling vibrations
Old Mar 10, 2013 | 04:48 PM
shoe3155's Avatar
shoe3155
Default growling vibrations
01 4x4 1500 5.9
I get a pulsing vibration that will come and go at any random speed. A bump can start and stop it. So can hitting slush with only one side of the truck. 4WD works and doesn't seem to trigger any vibes. Could it be binding u joint on drive shaft? Any other ideas?
Old Mar 10, 2013 | 04:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Are you talking about a wobble? If so , you need to check ALL the front steering and suspension components and verify which ones are good and which ones are not.
Old Mar 10, 2013 | 04:56 PM
shoe3155's Avatar
shoe3155
I don't feel it in the steering wheel at all, mainly on the floor boards.
Old Mar 10, 2013 | 05:04 PM
gdstock's Avatar
gdstock
Wheel balance, suspension parts worn as zman stated, bad tire. The list can go on.
Specific speed? Any other condition? Any noise associated with it? Need more info. Start by checking the suspension parts such as tie rods and such to eliminate.
Old Mar 10, 2013 | 05:07 PM
zman17's Avatar
zman17
Does it only do it in 4wd?
Old Mar 10, 2013 | 06:39 PM
shoe3155's Avatar
shoe3155
Does it in 2wd and sounds like a growl or grind
Old Mar 10, 2013 | 06:54 PM
zman17's Avatar
zman17
I suggest you jack the front up and check the hub bearing assemblies and axle ujoints.
Old Mar 15, 2013 | 03:34 PM
shoe3155's Avatar
shoe3155
While rolling about 15mph it was doing it and I slid it into 4hi and it stopped as soon as it engaged. Leads me to think transfercase is not disengaging all the way.
Old Mar 15, 2013 | 04:29 PM
Scooter78's Avatar
Scooter78
Might want to check your fluid level of your t-case. Sounds like you might have something grinding in there. Too much friction. Also, as the others already said, check all of your steering/suspension. Dodges are known for wearing them out.
Old Mar 15, 2013 | 05:29 PM
zman17's Avatar
zman17
Well you should probably verify that at least the the CAD is working properly. http://www.dodgeram.org/tech/repair/..._engagment.htm
And have you checked the hub assemblies and axle ujoints?
