Transmission question
Old Mar 10, 2013 | 08:24 PM
MHell2k13's Avatar
MHell2k13
Yep exactly. Bad?
Old Mar 10, 2013 | 08:33 PM
stewie01's Avatar
stewie01
I guess the question is how much was on the magnet?
I have an issue at 2k RPM's, and recently upgraded to the BW Governor Solenoid, and that's what was on my magnet, could be from over tightened bands..
I think it's normal to point to find stuff like that on the magnet...
Old Mar 10, 2013 | 08:36 PM
MHell2k13's Avatar
MHell2k13
Much more than was yours but no large shavings. It was all microscopic. So I don't know.
Old Mar 10, 2013 | 08:43 PM
stewie01's Avatar
stewie01
I wouldn't think that alone would be causing the issues.
But the screens on the governor solenoid could be clogged, or the passage way on the governor assembly thingy could be clogged.
You could pull it, 4 bolts and 2 torx screws and 2 clips, and check it out, clean the screen and/or upgrade to a BW Solenoid.
Assembly thingy:
Screens on Governor Solenoid:
Old Mar 10, 2013 | 08:55 PM
gdstock's Avatar
gdstock
Some gray sludge on magnet is normal. Shavings that will not stick to magnet can be brass (used for heat resistance) on bands and linings and float around suspended in fluid sometimes until filter traps it.
Old Mar 10, 2013 | 09:49 PM
MHell2k13's Avatar
MHell2k13
No shavings like that at all. I will def do the be governer
Old Mar 13, 2013 | 09:13 PM
MHell2k13's Avatar
MHell2k13
So I'm trying to figure out how to adjust the tv cable. I saw some good right ups but I can't figure it out. Mine isn't a white clip. It's black and I can't seem to figure out how to pry it off.
Old Mar 13, 2013 | 09:38 PM
gdstock's Avatar
gdstock
It is there...a little white insert in the cable jacket end.
Old Mar 13, 2013 | 09:57 PM
MHell2k13's Avatar
MHell2k13
Gods honest truth it's black. I see where it is but it's not white. I was wondering too do I have to replace the governer pressure sensor too with the solenoid?
Old Mar 13, 2013 | 10:00 PM
stewie01's Avatar
stewie01
You can get the BW Solenoid & Pressure Sensor on eBay for $96 + shipping.
