Truck won't start need help!
Old Mar 11, 2013 | 12:16 PM
loveitlifted's Avatar
loveitlifted
Default Truck won't start need help!
Hey yesterday I washed my truck and I sprayed down the engine. I used a very low setting. I started it about 5 min later and it ran fine. A couple hours later I went to go drive an it wouldn't start. It's cranking just fine and it sounds like it wants to start but it just won't turnover. I checked the distributer cap and it was bone dry. I'm not sure why it won't start and I'm looking for ideas. It's a 96 5.9 1500. Thanks!
Old Mar 11, 2013 | 12:24 PM
Pull a couple plugs, see if they are wet. (with gas)
Old Mar 11, 2013 | 12:38 PM
newman1367's Avatar
newman1367
How long since the plug wires were changed?
Old Mar 11, 2013 | 01:00 PM
loveitlifted
A changed the plugs and wires about 2 weeks ago
Old Mar 11, 2013 | 01:10 PM
newman1367's Avatar
newman1367
Gotta find out what your missing, spark or fuel. Spray any water towards the PCM?
Old Mar 11, 2013 | 01:21 PM
loveitlifted
What's a PCM? I mostly just sprayed down the side like the wheel wells ad the sides of the rad and stuff I tried t avoid electrical and other stuff
Old Mar 11, 2013 | 01:31 PM
Sooper's Avatar
Sooper
Remove the air filter from the air box. Put the box back together without the filter and see if it'll start. If yes...you need a new filter.
Old Mar 11, 2013 | 01:57 PM
loveitlifted
I have a CAI
Old Mar 11, 2013 | 02:16 PM
Powertrain Control Module. Your trucks computer or brain. Get it wet and your screwed, though it's kinda hard to get it wet unless you used a power washer and sprayed right at it.
I have a CAI
Did you get the filter wet?
Old Mar 11, 2013 | 02:32 PM
Sooper's Avatar
Sooper
True that water won't hurt the engine's intake charge in small amounts...if a dirty filter gets wet it'll clog fast and dirty. The dust turns to kind of a mud and then when it dries the air just can't get through anymore.
So regardless of if it's a CAI or not, remove the filter and try to start it.
