Trans cooler thread
Old Mar 11, 2013 | 05:46 PM
bigaaron's Avatar
bigaaron
Talking Trans cooler thread
in the market for one, but want to know what size for a gasser.
Old Mar 11, 2013 | 05:52 PM
redneck_ram's Avatar
redneck_ram
im interested too. want to see what the biggest one available is, doesnt matter if its gas, or diesel.
current aux cooler isnt cutting it.
Old Mar 11, 2013 | 06:28 PM
stewie01's Avatar
stewie01
Here ya go:
Originally Posted by dhvaughan
installed a new cooler:
I put on one of these recently and bypassed the stock cooler in the radiator. This is the one the diesel guys use.
Tru-Cool 4739-1 LPD47391
40,000 GVW rating, 45,000 BTU
The -1 does not include the cold weather bypass. If you live in a cold climate you'll need that bypass or the transmission might run too cold to engage overdrive.
it comes with 3/8" barbed fittings and a length of hose. I needed an additional length of hose to reach all the way around to the front of the condenser. it did not come with the zip-tie kit, which i got at Advance for about $5-6. tip when installing the zip tie in condenser - place it where you want it and measure it and center it and get it straight and mark the locations for the zip ties with a dab of paint or marker. then using a small screwdriver or nail, gently wiggle a generous hole through the condenser fins. then lift out the condenser and slip the zip ties into the holes from the back side.
here's a cheaper price at $132.50 incl free shipping.
http://www.ebay.com/itm/TRU-COOL-473...item4ac0ea4275
i got mine here awhile back for $145.
http://www.ebay.com/itm/Dodge-Truck-...item35bd937dba
Old Mar 11, 2013 | 10:06 PM
moe7404's Avatar
moe7404
great info guys. i found this external trans filter. one 3/8" tube ie most chrysler trans, i have one on my dak. one by wix 5/16 tube. my idea is that the inside one will need changed less.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
Old Mar 13, 2013 | 08:44 PM
roughrider97's Avatar
roughrider97
Just installed a cooler from Summit Racing. Rated for about 15,000 GVWR. Don't do much towing yet, yet a lot of free-spirited highway romps and some off-roading. Transmission runs right around 175 degrees now.
Old Mar 13, 2013 | 09:09 PM
bigaaron's Avatar
bigaaron
not 100% sure what I base it on: # of passess, GVWR, surface area Therefore I was curious what you guys had - let me know some part numbers if you got em
