Black Transfer case oil?
Old Mar 11, 2013 | 09:38 PM
Killerharen's Avatar
Killerharen
Default Black Transfer case oil?
We changed the transmission and transfercase oil this weekend and when we go to the trasfercase, the fluid was a black color and had the viscosity of water. My uncle who works on transmission for a living has no idea what it was, any ideas? The transmission fluid was normal.
Old Mar 11, 2013 | 10:36 PM
redneck_ram's Avatar
redneck_ram
t case uses atf+4. so it was obviously long overdue for a fluid change.
Old Mar 11, 2013 | 11:14 PM
Moochoff's Avatar
Moochoff
How many miles on the truck?
Old Mar 12, 2013 | 08:05 AM
Thoroughly used up transfer case fluid would be my guess and I don't work on transmissions for a living.....you changed it, now it's good so no worries. Maybe check it again after a couple hundred miles to make sure your not getting water in the t-case from anywhere.
Old Mar 12, 2013 | 03:59 PM
Killerharen
i forgot to tell that the fluid also smelt a little burnt. We put in atf+4 and the truck has 102000 miles. And its even shifting better than it was with the new fluid.
Old May 23, 2013 | 06:56 PM
Timothy Watrous's Avatar
Timothy Watrous
the haynes manual says to use dexronIII in the t case... so how sure r u ... do i need to change the wording in the manual?
the service manual says dexron II or atf plus
Old May 23, 2013 | 07:07 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Why are you digging up a 2 month old thread?
And ATF+4 is the replacement for Dexron II and ATF+
How old is your service manual, bro? lol
Old May 23, 2013 | 07:15 PM
Timothy Watrous
service manual i downloaded off here a few months ago... and i bought the Haynes manual a few months ago... and i wasn't gonna start a new thread...also my rear seal on my t case is leaking. i remember reading something bout a clip that breaks in there and causes t case failure is that right behind the rear seal. i figure check it wile im in there
Old May 23, 2013 | 07:19 PM
dodge dude94
Alright, well, either way, ATF+4 has superceded all other previous ATFs Chrysler has used in the past.
You're thinking of the snap ring failure. Yeah, since you've already got it apart, replace that bugger. There is an improved snap ring called the Transfer Case Saver.
Old May 23, 2013 | 07:57 PM
redneck_ram
trans takes atf+4, so regardless of what the SM says, id run atf+4 in the t-case anyway. if the seals go out they will leak into one another resulting in fluid contamination.
