ECM question
Old Mar 13, 2013 | 02:39 PM
windfreak0's Avatar
windfreak0
Thanks Zman. I'll also try to get the OBD codes to see if they point to anything. But not until after I get the new ig switch in.
Old Mar 13, 2013 | 02:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I hope the ignition switch solves it. But I'd like to know if the fuel rail is indeed plastic. Can you confirm please? Thanks.
Old Mar 20, 2013 | 09:21 AM
windfreak0's Avatar
windfreak0
Well, the fuel rail was plastic, so I disconnected the clip that holds the fuel line to it. Turning on the old ignition switch caused fuel to flow out, so I reassembled everything.
Double checked all the fuses in the glovebox--all good. Check again the relays in the engine compartment. Lo and behold there were two tiny fuses I had missed on the relay block. ASD fuse was fried. Turns out the previous owner had put a 10 amp in a 20 amp slot. Duh. Plugged a new 20 amp in and truck fired up. That was the only thing wrong! Time to clean 'er up and get 'er on the road.
Thanks for your help.
Windfreak
Old Mar 20, 2013 | 05:00 PM
zman17's Avatar
zman17
Windfreak
Congrats, and thanks for letting us know the fix.
