Low Oil Pressure When Warm
Old Mar 15, 2013 | 06:12 PM
dhvaughan's Avatar
dhvaughan
i'd call it fixed and not worry about it.
Old Mar 16, 2013 | 09:33 PM
clarke83's Avatar
clarke83
Thanks for changing the title for me. I was going to call it but it started happening again today but it dont start doing it unless i put it in reverse. If it was a bearing wouldnt it be knocking? I guess I will try putting a mech guage on it and see what happens
Old Mar 16, 2013 | 09:44 PM
stewie01's Avatar
stewie01
Excellent idea.
If the mech gauge says your oil pressure is good than it's probably a bad sending unit.
If the mech gauge says your oil pressure is bad than you might have some problems..
Old Mar 16, 2013 | 09:50 PM
clarke83's Avatar
clarke83
I replaced the sending unit twice because of the possibility of them being faulty from where they are made i think im just screwed haha
Old Mar 16, 2013 | 09:53 PM
stewie01's Avatar
stewie01
Just wait and see what the mech gauge has to say
Old Mar 16, 2013 | 10:05 PM
gdstock's Avatar
gdstock
Bearings may have excessive wear, but you would not hear them. You would however, hear rod bearings if they are going bad, which would be the next symptom to show up.
Check wth mechanical gauge to be certain. If it shows low, start looking for time and parts for a rebuild. And do not wait until it shells out - the resulting damage will make it more expensive!
Old Mar 18, 2013 | 05:13 PM
clarke83's Avatar
clarke83
Old Mar 18, 2013 | 05:17 PM
clarke83's Avatar
clarke83
I finally figured out how to post a pic of what i found in the oil pan and stuck in the pickup tube. There was alot of the foil looking metal peices and some other parts of the half circle so where ever that came from im guessing it was a whole circle
Old Mar 18, 2013 | 06:24 PM
guzman's Avatar
guzman
That bottom piece looks like sheathing for an electrical wire???
