plenum kit inbound
Take your time, keep like bolts together, mark things if you need to for easier re-assembly.
If you live in a salty area you can probably expect to break a bolt somewhere along the way
Have some PB Blaster nearby. And some RTV too.
Are you just doing the plenum pan/gasket or the whole Hughes kit?
It's really not to bad if nothing breaks.
VW hasn't been on lately, so here goes.... What color is the truck?
And I guess it is too late to tell you that you could have gotten the plenum kit from a member here cheaper.
ok im gonna try and respond to everyone at once... i ordered the entire plenum kit. i was not aware i could have gotten it for cheaper. i have a white 98 with a 360. i live in wv which is salty but i just bought the truck from baltimore a month ago whis is not too salty. PHEW!!! was that everyone? oh yeah i have lots of pb blaster in the garage. LOL!!
shoot i forgot one. i have already read the plenum stickey... at least as much as my A.D.D will allow
Trending Topics
Just take it slow and easy, and use that PB Blaster like it is cheap!
Make sure you do not overtorque the intake bolts. Are you doing timing set at same time? You are already right there doing plenum. If so, do a double roller set, instead of OEM Morse style chain.
Good luck!
