Cam suggestions?
Old Mar 18, 2013 | 01:22 PM
merc225hp's Avatar
merc225hp
You sure you want to use that cam in a 410 motor? Need to be looking in the .510+ range
Old Mar 18, 2013 | 03:22 PM
aofarrell2's Avatar
aofarrell2
.510 as in valve lift? If so then this one seems to fit the book:
P/N P5155566
Do you have any you would recommend?
Old Mar 18, 2013 | 03:41 PM
merc225hp's Avatar
merc225hp
I this case I am going to follow HeyYou's suggestion about cam's, get a hold of one of the cam manufacturers and tell them what your plans are and go from there. Get a hold of Hughes engines see what they have to say.
Old Mar 18, 2013 | 04:13 PM
aofarrell2's Avatar
aofarrell2
Sounds like a good plan to me. I'll call Hughes and also Comp Cams. Then I'll post the results.
