when i hit a bump truck shuts off ????
Old Mar 17, 2013 | 11:34 AM
tuffmudder's Avatar
tuffmudder
Lightbulb when i hit a bump truck shuts off ????
so i need some help when im driving down the road and i hit a pot hole or a speed bump anything really my truck shuts off. So i stop put it in park and it fires right back up every time. I'm gessing it going to be some sort of electrical issue possibly a loose ground somewhere but i have no clue where to start. I've shook, and tugged on the wireing harness and every wire i can get ahold of but it doesnt shut off only when im driving. Does anyone have any suggestions for me??
Old Mar 17, 2013 | 11:55 AM
Try the wiring for the cam/crank sensors.
Old Oct 25, 2019 | 11:28 AM
TonyB1500Sport's Avatar
TonyB1500Sport
I know this was an old post but did you get it fixed? I'm having the same issue, checked wires, fuses, replaced TIPM, throttle body... still shuts off on a bump. I do have a OEM remote start that was added, found one exposed wire, but didn't fix. Before i get new keys and ignition, just wanted to see if you found a solution?
Old Oct 26, 2019 | 08:02 AM
fj5gtx's Avatar
fj5gtx
If you look at the profile of the original poster, you'll see the last activity was 2013... don't think he's coming back.
Old Jan 7, 2020 | 01:47 PM
Lane73's Avatar
Lane73
Did you get a new ignition? And did it solve the problem. My 06 does the same thing everytime I hit a pothole. Not that big of a deal for me but im trying to fix the truck up for my daughter and she's a new driver.
Old Jan 8, 2020 | 06:42 AM
Moparite's Avatar
Moparite
When it happens do all the gauges die also? Also remote starts use relays that can go bad and cause this issue.
