Advice on tires for 4x2
Old Mar 19, 2013 | 09:13 PM
Jharding113's Avatar
Jharding113
Default Advice on tires for 4x2
Hi I have a 2001 ram 1500 2wd ext cab I have just stock 16in tires I believe and I want to start going through deeper mud and stuff like that I was wondering what size tires I should get and should I get new rims or just roll with the oem's. I also would like to know if I should get a lift kit because I don't have the most ground Clearance. Also anything that you think would help with achieving in going through deep mud but on a 18y/o's budget. Thanks for the help I really appreciate it!!!
Old Mar 19, 2013 | 09:14 PM
Jharding113
Links would also help in finding These hung also!
Old Mar 20, 2013 | 12:45 PM
joshmopar's Avatar
joshmopar
buy a 4x4.
Old Mar 20, 2013 | 01:07 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
And make sure you read where you should be posting.
Old Mar 20, 2013 | 02:51 PM
Moved to tech section.....
3" lift/leveling kit.
Stick with current rims.
Larger tires. Whatever you can afford, with a rather aggressive tread pattern. I wouldn't go any larger than 35's though, as even at that size, you are going to have clearance problems with only 3" of lift.
Old Mar 20, 2013 | 03:05 PM
guzman's Avatar
guzman
Default Mud
Make sure you have good tow hooks on both ends of the truck if your set on plowing mud with a 4x2....and maybe some waders.
Old Mar 20, 2013 | 03:11 PM
Changing your title to something more appropriate as "Help!!!!!" is generally reserved for those who can't start their trucks.
Old Mar 20, 2013 | 06:05 PM
Johnn123's Avatar
Johnn123
4x2 + mud = bad idea. You will get stuck easy everytime.
Old Mar 20, 2013 | 06:34 PM
dlyter09's Avatar
dlyter09
Not really true.. With proper tires and a locker and some good driving it will be a good offroader... Hell my truck is 2 wheel drive.. I havent had any issues with getting to places like that.. Granted I knew my limits and have driven 2 wheel drives many of places..
Old Mar 20, 2013 | 10:44 PM
Johnn123's Avatar
Johnn123
For the thick stuff I think he means it isnt. Good locker would help great tho, compared to a one legger.
