oil pan pick uptube
Old Mar 23, 2013 | 07:29 PM
byronpen's Avatar
byronpen
Default oil pan pick uptube
ok, i rebuilt my hole front end. that turned out great.
I droped my oil pan to replace the gasket, and noticed my oil pick up tube was full, so i went ahead and replace the oil pump and pick up tube. and after i started my truck a loud banging was happening. im thinking that the pickup tube could be getting hit. it gets louder with the high rpms. has anyone ever had this problem. i dont think i it could be the oil pump.
Old Mar 23, 2013 | 07:35 PM
crazzywolfie's Avatar
crazzywolfie
did you remove the oil dipstick before you removed the pan?
Old Mar 23, 2013 | 07:44 PM
byronpen's Avatar
byronpen
yes and even so. there is a guide rail in the pan that shroud stop that from happening
Old Mar 23, 2013 | 07:56 PM
redneck_ram's Avatar
redneck_ram
did you prime the new pump?
Old Mar 23, 2013 | 08:00 PM
byronpen's Avatar
byronpen
ok have never done that. well how do you do that
Old Mar 23, 2013 | 08:02 PM
redneck_ram
procedure is towards the bottom of the page.....
http://www.pavementsucks.com/tech-article-31.html
Old Mar 23, 2013 | 08:12 PM
byronpen's Avatar
byronpen
would an unprimed pump make such a loud bagging
Old Mar 23, 2013 | 08:16 PM
redneck_ram
an unprimed pump can kiss your motor goodbye
Old Mar 23, 2013 | 08:24 PM
gdstock's Avatar
gdstock
Without being primed, pump may not start pumping oil. Did you notice if you had oil pressure?
Old Mar 23, 2013 | 09:07 PM
DPR250R's Avatar
DPR250R
Did you note the position of the tube on the old pump and install it the same way on the new pump?
Do you have pressure?
Also, I have replaced my pump once and main seal twice without priming... truck still runs like a champ although the main seal (or something else) still leaks... lol... So while it is a good idea to prime, if you forget it is not automatic death to your engine.
