question about cams
Old Mar 28, 2013 | 03:16 PM
joshmopar's Avatar
joshmopar
Default question about cams
So im getting ready to do the intake, 1.7's, sct, full tune up, throttle body, timing chain, and water pump. I am wondering if a cam would be worth the money? and if i can get one that wont have me pulling the pistons to have them cut for valve reliefs?
Old Mar 28, 2013 | 03:38 PM
gdstock's Avatar
gdstock
I have seen dscussion on RV cam, but I have NO idea what and RV cam is. There are several that have changed cams, and hopefully when they post up,someone will tell what a RV cam is!
Old Mar 28, 2013 | 04:39 PM
aofarrell2's Avatar
aofarrell2
Never had experience but from other people I know the RV cam increases torque under 3000RPM for better towing.
Old Mar 28, 2013 | 05:20 PM
joshmopar's Avatar
joshmopar
What is this RV cam? Are yall talking about the cam used on older LA motor that were in stuff like converion vans and small RV's
Old Mar 28, 2013 | 05:23 PM
gdstock's Avatar
gdstock
Ha! That's whatt I was wanting to know, so make sure you find out - so we can all find out!
Old Mar 28, 2013 | 05:49 PM
aofarrell2's Avatar
aofarrell2
The RV cam I was referring to is not from a LA. It simply is a different grind, I believe it is a very smooth, not lopey cam.
Old Mar 28, 2013 | 06:05 PM
joshmopar's Avatar
joshmopar
Looking at running the wiplash cam from Hughes. Although im not very savy at knowing weather or not this will be a good cam or not for street use. And am wondering if with the other mods im going to do will it be worth it? Also does anybody know if it will work with the 1.7rr?
http://www.hughesengines.com/Index/p...=&partid=26252
Old Mar 28, 2013 | 06:11 PM
merc225hp's Avatar
merc225hp
No go on that cam. With stock heads and valve springs your limit is .480 lift max.
Old Mar 28, 2013 | 06:15 PM
Ham Bone's Avatar
Ham Bone
If you do a cam swap you should do it right.
Cam
Heads
Valves
Springs
Lifters
Pushrods
All that must be taken into account .
All your tune up stuff will give you a nice little power increase as it is
Old Mar 29, 2013 | 05:19 PM
joshmopar's Avatar
joshmopar
True, true. Gonna get her runnin right and then worry about other fun stuff.
