oil in intake after plenum repair, pcv?
Old 04-01-2013, 05:21 PM
guzman's Avatar
guzman
guzman is offline
Default Pcv
i find it easiest to just pull the hose off the intake while the truck is warm and twist the hose/pcv valve out.
Mine were not that easy=real sumbeech!!
  #32
Old 04-01-2013, 08:30 PM
coldsteel5's Avatar
coldsteel5
coldsteel5 is offline
Originally Posted by gdstock
Search catch can on ebay. I put one on mine and plenum is still clean. Typically used in racing. I have a better photo - just can't find it. Catch can is below gauge set.
This is draining it during oil change.
how effective are these at catching the oil? it looks to be the nozzles are real close together and just an empty canister with no seperator or baffle inside that would allow for alot of oil to flow right through. they are about 20$ on ebay.
the pcv valve comes out nicely. the plastic pipe piece on the passenger valve cover just spins around easily but will not pull out. when I had the covers off I tried everything to get it out without breaking it but it just spins in the grommet.
  #33
Old 04-01-2013, 09:26 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
I broke mine when I replaced it.
I think the problem is the grommet; I can pull the PCV out of the 76 easy, but it's grommet is a little softer.
Oh, wolfie, thanks for the link. I guess I'll have to go shopping here soon.
  #34
Old 04-01-2013, 09:52 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
the cheap $20 ones on ebay are empty canisters. the more expensive ones would have something in it separate and hold the oil. this is why i chose to go with a oil/water separator. it is cheap and the bowls are usually clear so you can see how effective it is.
  #35
Old 04-01-2013, 11:12 PM
coldsteel5's Avatar
coldsteel5
yea im going to make one soon as I get the chance to go to the department store. Does this mean I have to pull the intake mani off and clean it out again?
  #36
Old 04-01-2013, 11:48 PM
dodge dude94
Nah, seafoam it. That will work well enough. You mostly need to stop the PCV from sucking in oil so it stays off your valves and pistons.
  #37
Old 04-09-2013, 04:52 PM
coldsteel5's Avatar
coldsteel5
finally got the diy catch can installed, and after a few days it seemed to be working nicely. I want the "in' hose hooked to the pcv, and the "out" going to intake, correct? makes sense. Name:  oilcatch_zps2fd7574d.jpg
  #38
Old 04-09-2013, 05:11 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Yes, you are correct. Nice job, I just did this with a cheapo spray gun filter(I have a thread). You should add the pics and the info on how much and where you got the part's to that thread. Only thing I would do different is to use fuel hose instead of the air hose. I want to make that thread a diy with different options, and your's is the first with a different option. So add that info.
  #39
crazzywolfie
that looks like the $12 oil/water separater from lowes.
http://www.lowes.com/pd_221024-47120...7C1&facetInfo=
looks good. did you seal the drain valve on the bottom? only reason i ask is i think the valve at the bottom need so much pressure to keep it closes and if you have 0 pressure it will stay open and you could have a tiny vacuum leak. it does look like it is doing its job tho. i just pressed the drain valve on mine the other day and the stuff that came out smelled extremely gassy.
  #40
Old 04-09-2013, 05:16 PM
zman17's Avatar
zman17
zman17 is offline
Amazing how much oil is in it after only a few day's.
Quick Reply: oil in intake after plenum repair, pcv?
