leaking oil pan
Old Apr 1, 2013 | 08:54 AM
zach01's Avatar
zach01
Default leaking oil pan
hey my oil pan is leaking pretty good i already picked up a new gasket and i plan on doing the job this week i got a week off work so while i got the pan off is there anything else i should replace or check
Old Apr 1, 2013 | 09:09 AM
Is the gasket leaking, has the pan rusted out? Front/Rear main seal?
Depending on mileage, and how your oil pressure is doing, might not hurt to consider replacing the pump while you are there, along with the rear main seal.
Old Apr 1, 2013 | 10:28 AM
clipper77's Avatar
clipper77
Make sure the screen on the pick up tube is clean.
Old Apr 1, 2013 | 02:55 PM
Blackbox19's Avatar
Blackbox19
Took me a whole 1 hour to drop the pan, pull the oil pump and clean everything back up.
Take the pick up tube off the pump and flush it real good. Mine was full of crud.
Dab of sealant at the corners of the gasket front and rear and you good on leaking.
You do not need to drop starter or that inspection plate. But it helps.
Old Apr 1, 2013 | 03:33 PM
guzman's Avatar
guzman
I would install a new pump since you have alot of miles on the truck, good idea to prime it before installing also. Have fun!
Old Apr 1, 2013 | 10:56 PM
dhvaughan's Avatar
dhvaughan
if your rear main seal is leaking, its a good opportunity to replace it.
also the oil pump.
i was not able to get my oil pan off without removing the f***ing starter, which was the hardest part because it was torqued to 50 million foot pounds.
http://www.pavementsucks.com/tech-article-31.html
get the little bottle of permatex anaerobic sealant for the rear cap.
Old Apr 2, 2013 | 05:26 AM
zach01's Avatar
zach01
ive never done a rear main before i always heard you had to remove the tranny.. is that so or ? i didnt see a DIY rear main the DIY section
Old Apr 2, 2013 | 10:20 AM
We have a two-piece rear main seal on our trucks. So, no need to drop the trans. Just remove the rear main cap, loosen the others, and drive the upper half of the seal out. (use a wooden dowel, or some such, nothing that is going to marf up the surfaces...) lower half is easy when you have the cap in your hand.
Old Apr 8, 2013 | 05:21 PM
zach01's Avatar
zach01
i'll see if its leaking and maybe try it but its leaking from the front from when I messed up the gasket doing my t chain..
