How to remove Pitman arm When you break the pitman arm puller
Old Apr 2, 2013 | 09:48 AM
dassip's Avatar
dassip
Default How to remove Pitman arm When you break the pitman arm puller
I need to get my Steering box out of my truck to replace it and i tryed to pull the pitman arm and the puller bolt snapped right off. Any other ideas
Old Apr 2, 2013 | 09:54 AM
coldsteel5's Avatar
coldsteel5
Where did you get the puller from? If it is cheap quality like harbor freight tools it wont work. I broke 2 before I had to spend $ for a good one. A little bit of heat seemed to help also
Old Apr 2, 2013 | 10:11 AM
I use two large hammers... (3 pounders...) Hold one against one side of the arm, and SMACK the other side with the other one. Usually, two or three good hits, and it pops right off.
Old Apr 2, 2013 | 10:26 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
If you value your eyes, but safety glasses on.
Old Apr 2, 2013 | 12:30 PM
merc225hp's Avatar
merc225hp
Buy a new pitmanarm probly cheaper than a new tool.
Old Apr 2, 2013 | 04:52 PM
redneck_ram's Avatar
redneck_ram
had the same issue on my buddys 99 1500. couldnt get the pitman arm off... used some heat, and mopar penetrant. then out the puller back on, tightened it, and proceeded to use a hammer. came off after a couple hits, and retightening of the puller.
