2000 dodge ram 1500 trans problem
Old Apr 3, 2013 | 07:34 PM
dec2570's Avatar
dec2570
Default 2000 dodge ram 1500 trans problem
Hello everyone, I need some help. I have a 2000 dodge ram 1500 4x4 with 205,000 miles on it and without notice while driving to work as pulling into the parking lot my transmission started to slip and then went nowhere.
it finally went into gear and I parked it. Got it towed home and after it came off the flatbed it acted like nothing was wrong. It sat for a couple days and I tried it again and it wouldn't go and reverse was making a winding sound. I was advised to change the filter which I did.
It drove perfect for about 4 days and the same thing stared slipping and had the same winding noise while in reverse.
My question would would be should I have the trans flushed with the high mileage or any other sugesstions.
any help would be great thanks in advance
Old Apr 4, 2013 | 07:51 AM
Welcome to DF! I will move this to the 2nd gen Ram section. Lots of knowledgable folks there can point you in the right direction.
Old Apr 4, 2013 | 08:17 AM
rumble_truck's Avatar
rumble_truck
Welcome to the 46re woes. As for diagnosing whats wrong, i'm not great sorry I cant help, welcome to forum
Old Apr 4, 2013 | 09:25 AM
stewie01's Avatar
stewie01
I would not have it flushed.
What's the fluid level? Have truck at normal operating temp, and transmission in N to check properly.
Drop the pan, see what's on the magnet, check the governor solenoid (clean or replace if needed), maybe a band adjustment and see what happens....
Old Apr 4, 2013 | 04:25 PM
dec2570's Avatar
dec2570
I just changed the filter and cleanrd the solenoids, Not much on the magnet except some heavy gunk with a metalic look but poured right out of the pan. Then it drove fine for 4 days and them started acting up again. like before I changed it My plan is to drop pan again to check. Thanks for the help!!!!!
