Old Aug 7, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
What power steering fluid should I use on my 98 Dodge Ram SLT?
Old Apr 4, 2013 | 09:06 AM
Metalgearsolid_x's Avatar
Metalgearsolid_x
Default What power steering fluid should I use on my 98 Dodge Ram SLT?
So it seems like there's back and forth debate on what power steering fluid we are allowed to use. Some swears by using the Mopar MS5931 while others suggested Atf-4.
Here's the TSB on Power Steering fluid: http://dodgeram.info/tsb/2003/19-005-03.htm
...... MS5931 and MS9933 are Amber/Yellow in color. All three fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
I have to bleed my power steering fluid next week. I was wondering, if I can use this fluid for my bleed? it's color Amber as the TSB suggests AND it's compatible with MS591
Valvoline® Power Steering Fluid
Helps stop squeals while preventing corrosion, oxidation and wear
•Meets GM, Ford and Chrysler specifications
•Keeps seals and o-rings pliable
•Prevents leakage and squealing under severe conditions
•Prevents wear, foam and oxidation
•Protects against pump breakdown
•Meets GM part number 1050017 (Spec. 9985010), Chrysler Spec. 5931 and Ford Spec. M2C128C&D
Color Amber
•Container Type Plastic
•Not for use in Honda or Acura vehicles
Cost: ONLY $4.79 for quart before coupon codes from Advance Auto which is very affordable.
Thank you in advance
Old Apr 4, 2013 | 09:21 AM
stewie01's Avatar
stewie01
I use ONLY cheap unbranded Power Steering Fluid... Haven't had any problems.....
Old Apr 4, 2013 | 09:58 AM
Metalgearsolid_x
So I should be good with the valvoline, right?
Old Apr 4, 2013 | 10:04 AM
Darren270's Avatar
Darren270
I use Valvoline and have had zero problems with it.
Old Apr 4, 2013 | 10:30 AM
x2 on the cheap ps fluid. Never had an issue.
Old Apr 4, 2013 | 11:13 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I've got a mix of the Mopar stuff and ATF4 in mine. No issues like I was told.
Old Apr 4, 2013 | 12:12 PM
Metalgearsolid_x
Thanks guys! really appreciate your help (quick replies).
Another quick question, how much fluid do I need? 32 oz enough for drain and fill? or should I get two bottles?
Old Apr 4, 2013 | 12:19 PM
Get two, and thoroughly flush the system.
Old Apr 4, 2013 | 12:23 PM
merc225hp's Avatar
merc225hp
1.3 liters or 2.7 pts is what the fsm says it will hold, me atf+4 is all I use.
Old Apr 5, 2013 | 09:49 AM
Metalgearsolid_x
Thanks guys! You guys are great help!
I also wanted to change the inline filter too because it's inexpensive but I keep seeing two different size piping (3/8" or 1/2"). I have 5.2L 4WD SLT model
http://shop.advanceautoparts.com/web...teering+filter
•New; w/Aluminum Housing;Our MagnaPure In-Line Filter measures 1.25" X 3" w/ 3/8" Outer Diameter Neck (For 3/8" ID Hose) And Will Only Fit Applications Where Space Allows.
•New; Our Magnetic In-Line Filter measures 2 1/4" X 5" w/12 mm Outer Diameter Neck (Designed For Use With 7/16" or 1/2" ID Hose) And Will Only Fit Applications Where Space Allows.
