wiring help
Old Apr 4, 2013 | 10:31 PM
Blaine Cash's Avatar
Blaine Cash
Default wiring help
My 2000 Ram 1500 was stolen but recovered. The *** cut the wires on the terminal block to the ingnition switch. I got a new switch and cylinder but need to know the color sequence for the wiring. I have heavy gauge red /black and brown/pink/ blue/Yellow/Solid black (I think that is it). What order do they go? I can hot wire it easily, but dont want to burn anything up if I get them in the wrong order.
Old Apr 4, 2013 | 10:37 PM
aofarrell2's Avatar
aofarrell2
https://dodgeforum.com/forum/2nd-gen...s-manuals.html
Download the correct FSM for your vehicle. It will contain the wiring diagrams you need.
Old Apr 4, 2013 | 10:58 PM
stewie01's Avatar
stewie01
^^ That's the Parts Manual!
Here's the link to the FSM: https://dodgeforum.com/forum/2nd-gen...e-manuals.html
2000 should do you just fine.
Old Apr 5, 2013 | 08:28 AM
Blaine Cash
You are awesome, I searched every word I could think of trying to find those. I will let you know if it helps
Old Apr 5, 2013 | 01:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
At least you got it back without a lot of other damage. I'm going to change the name of your thread to "wiring help", which is better suited for the tech section, as soon as you give the OK.
Old Apr 6, 2013 | 09:56 AM
Blaine Cash
Default Thanks!
I got it all put back together bu cant get power to the radio or the air bags, so who knows what he did there.
Old Apr 6, 2013 | 11:14 AM
redneck_ram's Avatar
redneck_ram
check the fuses in the in dash fuse box. there is also an IOD fuse, that has a black clip holding the fuse in. 10a fuse i believe. check em out, and report back!
