What transmissions fit a 1996 1500?
Old Apr 7, 2013 | 10:54 AM
MHell2k13's Avatar
MHell2k13
Default What transmissions fit a 1996 1500?
1996 1500 5.9 has obd2 port so I was thinking it was 46re but when I ordered my pan gasket from autozone for the exact truck stated aboveit didn't fit the tranny. So I was wondering what tranny I may have and what would work
Old Apr 7, 2013 | 11:16 AM
zman17's Avatar
zman17
Retired Moderator - RIP
They all fit. Thing is you need one from a 96 to 97 for it to work correctly. Maybe a 98. Any newer tranny will require the changing of the internal electronics. And just so you know, 94 and 95 won't work at all. Also the tranny needs to be from a 4x4 or 2wd to match whatever your truck currently is.
And btw, a 96 has a 46re. You should get one of these regardless.
http://www.dodge.com/wccsapp/univers...ull&category=U
Old Apr 7, 2013 | 12:00 PM
Arde's Avatar
Arde
Your trans. pretty much has to be a 46RE, nothing else will bolt up and work properly.
Whenever I've bought trans. gaskets, I get two in the box. One fits, and one is for something else. Sounds like AZ didn't give you what you paid for.
Old Apr 7, 2013 | 12:03 PM
zman17's Avatar
zman17
+1... A wix filter(which you should use) comes with 2 gaskets. The right one and one for a 727 that is slightly different IIRC.
Edit: Unless someone has already replaced the gasket previously and /or ruined the oem gasket, the OEM tranny pan gasket is reusable.
Old Apr 8, 2013 | 10:19 AM
MHell2k13's Avatar
MHell2k13
Hey thanks a ton again for the help. I indeed ratios about the electronics I just was confused because I know in 96 they started changing things do there are 2 diff models
Old Apr 8, 2013 | 10:21 AM
MHell2k13's Avatar
MHell2k13
I hate autocorrect haha zman how do you like the trans cooler? You think it's a worthy upgrade?
Old Apr 8, 2013 | 11:28 AM
zman17's Avatar
zman17
Yes on the cooler and you should delete the check valve.
