what damage will a bad front axel u-joint cause?
Old Apr 9, 2013 | 09:33 PM
smoky614's Avatar
smoky614
Question what damage will a bad front axel u-joint cause?
Alright, i got a 94 1500 4x4. both front axle u-joints are bad,(driver worse then passenger) they both got some give to them and the driver side makes a kinda loud knocking, clicking sound(But it aint loud enough to be a thumping sound yet). Passenger is a faint clicking sound. I aint got the tools to do it myself and i wont have the money to get it fixed till atleast this weekend. Ive been told that itll start to make a really loud thumping sound before my wheels will lock up and stop me dead. but im worried that if i keep driving it itll tear up my axle. Im pretty sure if nothing else it could blow my axle seals. Im i on the right track or over thinking it and do Yall think itll make it a week(another 50-75mi) or should i let it sit till i can fix it?(I just noticed the noise today, had some fun last night. Think that was the straw on the camels back!)
Old Apr 9, 2013 | 10:00 PM
QuadCabLuv's Avatar
QuadCabLuv
Ive seen and heard of bad ujoints puttingvout enough vibrations to destroy diffs and t-cases.
Old Apr 9, 2013 | 10:05 PM
joshmopar's Avatar
joshmopar
I have driven a truck with a front axle ujoint that had peices missing from the cap. your good till the weekend.
Old Apr 9, 2013 | 10:18 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^this is a high probability!!
Wow...so you're willing to suggest someone drive a KNOWN poor condition that could cause an accident? Driver side could indeed lockup to then pull driver side and into whatever is there. Have you driven the OPs truck? Have you put your hands on it and evaluated it as a mechanic with liability insurance and the like? You want to take that chance?
Don't post crap like that!!
OP, with that much noise and physical feedback you are describing it's highly suggested that you do not drive it further. Where are you located and have you received a quote on replacing both ujoints?
If only you could just take out the axle shafts and put the unit bearing back in. Then it would roll like manual locking hubs.... LOL
Old Apr 9, 2013 | 10:22 PM
kejobe's Avatar
kejobe
Should be fine till this weekend. Just try not to make tight turns until it gets fixed. It'll put more stress on it which could cause it to go.
But, just be aware that, as stated, if it goes out it can destroy a lot.
Be easy with it.
Old Apr 9, 2013 | 10:35 PM
dhvaughan's Avatar
dhvaughan
a mild clicking will probably be ok for a little while. my passenger side was clicking pretty good a couple of years ago, and i drove it for several more days until i had time to fix it.
as said, be easy and don't make any tight turns - period. this is where it would most likely break something.
if it starts popping, or making other noises - park it.
you can test the amount of play by grabbing the inner axle and rotating it back and forth against the outer half. the play in the bearing cap starts as a clicking, then a clacking, then popping in turns, then it breaks.
Old Apr 9, 2013 | 11:05 PM
smoky614's Avatar
smoky614
Well, I think Im gonna play it safe and let sit for a few days. I can barely afford this, Ill be screwed if I really tare something up! But thanks for yalls advice.
I'm going to go get an estimate tomorrow, I'm hoping It only a couple hundred! Ive seen some estimates on here for like 800bucks, Thats crazy!!! But I live in Ohio, About 45min west of Toledo.
Old Apr 9, 2013 | 11:17 PM
dhvaughan's Avatar
dhvaughan
you got anyone with tools and know-how that can show you how to do this.
everybody has to learn sometime.
the only real difficulty is getting the big axle nut off. you'll need to own or borrow a 1-11/16 socket. if you can't break it loose with a long pull bar and pipe, you can take it to a very close, local shop and have them break it loose, then reinstall at a modest 100 pounds of torque so you can drive it home and take it back apart.
here's a good how to:
http://www.pavementsucks.com/tech-article-5.html
http://www.pavementsucks.com/tech-article-3.html
Old Apr 9, 2013 | 11:20 PM
dhvaughan's Avatar
dhvaughan
an experienced mechanic could replace both axle ujoints in about 3 hours or less. i don't know what the labor rate would be - maybe 4 hours.
it won' be cheap to pay someone else to do this.
Old Apr 10, 2013 | 12:16 AM
smoky614's Avatar
smoky614
I know, that's whats killing me. I know how to do it, it's just that the majority of my tools came up "missing" not to long ago, I barely got a wrench set left!!
