Possibly blend door?
Old Apr 18, 2013 | 02:44 PM
RareColorRam1995's Avatar
RareColorRam1995
Originally Posted by zman17
You are working on a 2001 not a 95 right ? The motor is down by the floor/tranny tunnel. Did you get some help and check like I described? You need to see if that motor is rotating and how much.
It's not the mechanism with a rod connected to it right behind the glovebox? If not, is it behind the plastic bulge held on with two screws on the tranny hump?
Old Apr 18, 2013 | 03:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The motor for the blend door is the one by the tranny hump. One of the screws is quite hard to get to. But right now you just want to see if it (the motor) turns or if it's jammed.
Old Apr 18, 2013 | 03:24 PM
RareColorRam1995
The silver piece coming out of the center of the actuator I guess it is, does not turn on any setting. Would it be worth my whole to check and see if all lines are hooked up in the control panel for the A/C and heat? Heat blows out of every setting of fan speed/temp/and location.
Old Apr 18, 2013 | 03:29 PM
zman17's Avatar
zman17
When you move the dial (hot to cold) on the control panel does the motor do anything at all?
RareColorRam1995
Everything looks connected in the control panel.
Old Apr 18, 2013 | 03:30 PM
RareColorRam1995
No movement at all from the motor. I assume I'm suppose to be looking at the silver piece in the middle of it.
Old Apr 18, 2013 | 03:33 PM
zman17's Avatar
zman17
So the motor makes no noise and does not even move like maybe a 1/8" in either direction?
Old Apr 18, 2013 | 03:36 PM
RareColorRam1995
No movement. No noise I can hear.
Old Apr 18, 2013 | 03:40 PM
zman17's Avatar
zman17
In that case you might be lucky and don't have to take the HVAC box back out. Either the motor itself is bad, the control panel is bad or the wiring. Now all you have to do is figure out which one.
Old Apr 19, 2013 | 10:49 AM
RareColorRam1995
Hoping and praying for motor *fingers crossed*
