5.9 or 5.2
Old Apr 16, 2013 | 09:12 PM
szpilafam's Avatar
szpilafam
Default 5.9 or 5.2
I went out and got a dodge truck. I have worked on my sons its a 5.2, I have got a slightly used 1995 full bed 4x4 it says its a 5.9 but it looks dead on like my sons, is there any way to tell the difference, shouldn't there be a plate or something on the block so I can tell if this is the original engine? it's obvious that the tranny is not the original.
Old Apr 16, 2013 | 09:15 PM
stewie01's Avatar
stewie01
I've got no idea how to tell them apart by just looking at them in an engine bay.
But I'd like to know...
Old Apr 16, 2013 | 09:25 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
From the top, the 5.2 and 5.9 look the same.
The 5.9 has a vin code of Z. I don't remember what the 5.2 has.
But the 5.2 is internally balanced, so it won't have a harmonic balancer on the crank.
Old Apr 16, 2013 | 09:29 PM
It will still have the balancer. (actually, its a Harmonic dampener.....)
According to theory, above the starter motor, should be a string of numbers.... in the middle will be either 318, or 360.
Old Apr 16, 2013 | 09:41 PM
gdstock's Avatar
gdstock
From FSM -
Number stamped on block.....
The engine serial number is stamped into a machined pad located on the left, front corner of the cylinder block. When component part replacement is necessary, use the engine type and serial number for reference.
X M AAA YYY 0000
X=Year
M=Plant
AAA= Engine Displacement
YYY=Month/Day
0000=Engine Serial Number
Old Apr 17, 2013 | 03:50 AM
JoshSlash87's Avatar
JoshSlash87
It used to be so easy for the old ones lol 360s generally had a 4bbl carb and 318s had a 2bbl. Not sure if I seen any 360 markings on my sisters block when I redid her motor.
Old Apr 17, 2013 | 01:25 PM
Scooter78's Avatar
Scooter78
5.9 will have a notch taken out of the harmonic dampner, whereas the 5.2 will be even all the way around. Dead giveaway evertime.
