Does not turn over-pic added
Old 04-19-2013, 09:53 AM
rustynuts's Avatar
rustynuts
rustynuts is offline
I will have to check for that when I get back home from work tonight
I will report back.
Thank-you so much for your help on this--I dont have the cash to get it towed in and looked at right now--want to try and work my way through with the help here first before I throw in the towel
Old 04-19-2013, 09:54 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Does it do this when it's just wet/damp/humid outside or all the time?
The reason I ask is because these trucks get cracked distributor caps and they like to do that when they're cracked.
Old 04-19-2013, 09:56 AM
rustynuts's Avatar
rustynuts
also, it sounds like it wants to start on some turns--the engine sputters then it just stops even if my foot is pummping the fuel pedal
Old 04-19-2013, 09:58 AM
rustynuts's Avatar
rustynuts
Humid/damp wet has been a correlation for this issue in the past--did it to me also last spring, but the issue then cleared up. It is much worse now
The distributer cap replace sounds like a cheap fix and will not hurt to try--thanks!
Old 04-19-2013, 10:00 AM
dodge dude94
Yep. Just remember to get a cap and rotor (might as well replace both since you're back there) that have brass contacts, since brass is a better conductor of electricity than aluminum.
And ALSO!! Get a smallish square of sand paper and sand the distributor shaft after you take the rotor off. Don't be like me and snap two rotors because you weren't able to push them down all the way.
Old 04-19-2013, 02:53 PM
chromed95's Avatar
chromed95
chromed95 is offline
Have I mis understood somewhere?...You said it's not turning over which to me is saying the engine is not turning over period. Is it not firing? But looks like you are on the right track with these guys help. Good Luck!
Old 04-19-2013, 04:01 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
Did it sit all winter with gas in it? Did you put any stabil in the gas? May just be a issue of bad gas. Try spraying some starter fluid down the throttle body and see if it starts.
Old 04-19-2013, 07:32 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Check engine light is on when I'm turning the key to try to get it to start and turn over.
"turn over" what does that mean? The engine does not spin when you turn the key or the engine won't start but cranks/spin's ?
Old 04-19-2013, 08:44 PM
rustynuts's Avatar
rustynuts
not turnover=does not fire
sorry for any confusion - in this area of the nort woods thats what I have heard for this situation, maybe I hang with the wrong crowd who knows
Tonight it is 25 degrees and dry air now from winds all day
the truck started up on first turn
with that, i'm thinking the dizzy cap must be cracked like mentioned
guess I remove entire air cleaner to even have attempt to touch the dizzy back there--what were the engineers thinking.....
dizzy= distributer
Old 04-19-2013, 09:07 PM
zman17's Avatar
zman17
zman17 is offline
Not turning over= engine does not crank/spin as far as I know. Not starting or firing up is a whole different deal.
Quick Reply: Does not turn over-pic added
