Gear indicator cable broke
Old Apr 25, 2013 | 08:23 PM
Thornloe Pride's Avatar
Thornloe Pride
Default Gear indicator cable broke
Well today has been a rough day. Had my dash apart trying to fix something in the cluster and I pulled the cluster out too much and pulled the gear indicator off the column. Can't tell if I pulled it out or broke it. The cable is still attached to the cluster. I didn't look fast enough to see exactly where the cable attached to but I'm assuming close to shifter. Haven't been able to find much on the issue. Anyone have any advice?
Old Apr 25, 2013 | 08:33 PM
dhvaughan's Avatar
dhvaughan
seems like the PRNDL is a module that screws into the back of the cluster and has the cable attached. the other end of the cable clips to the shifter.
you may have pulled the clip loose, or you might have broken the cable. find the white plastic clip with the adjusting **** and look for the end of the cable.
worst case you might have to buy a PRNDL module from dealer or junkyard. or you might be able to splice the cable back together with something. maybe tie a knot or loop in each end and splice in a piece of wire.
Old Apr 25, 2013 | 08:34 PM
Grab the 01 service manual, and look for the PRNDL adjustment procedure, has some nice pics.
Old Apr 25, 2013 | 08:43 PM
Thornloe Pride
Okay thanks guys. Ill look at it tomorrow. Anyone know if the PRNDL cable etc from a 96 (parts truck) will fit mine (98)?
Old Apr 26, 2013 | 10:48 AM
Fair bit changed between 96 and 98... so, its a crap shoot whether they will interchange or not.
Old Apr 26, 2013 | 05:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
96 won't work. I have all the parts you need to fix it for sale in the classified section,
Old Apr 28, 2013 | 09:09 PM
Thornloe Pride
I was able to use the one off the 96. Wasn't a perfect fit but with some adjustment it seems to work fine. Thanks guys!
Old Apr 29, 2013 | 05:20 PM
zman17's Avatar
zman17
What part of it worked please? Just the adjusting screw assembly on the column? No way the indicator/cable assembly should work on the back of a 98 dash assembly. Just curios. Thanks
Old May 1, 2013 | 12:03 PM
Thornloe Pride
I used the PRNDL off the 98 and used the cable and clips off the 96. The adjustment screw assembly was the same and the clip that connects the cable to the PRNDL was not quite the same but very similar. It installed fine however the problem was the cable travel was too short. When in park it was reading between park and reverse. So I cut some of the plastic on the back of the PRNDL off that was restricting travel and this extended travel enough that I even had some adjustment available. Then I sanded down the plastic where I cut so it would be smooth for the cable. I did it in a manner that there isn't any stress on the cable so it shouldn't break overtime. Sorry, I should have taken pictures. Basically it works if you are in a bind and you have some time to spare.
Old Mar 30, 2021 | 11:36 AM
Teresa Carroll's Avatar
Teresa Carroll
Default Shift indicator cable
I have searched for a shift indicator cable for my 1995 Dodge Ram 1500 - it is stretched
