Death wobble HELP!
Old May 1, 2013 | 10:27 AM
MegaJamBox's Avatar
MegaJamBox
Default Death wobble HELP!
Truck has a 2"leveling kit in front and new tie rod ends and sleeve upper/lower ball joints and wheel bearings.
Yesterday went to a tire shop to get 35/15/16.5 super swamper tsls mounted and balanced and wanted my truck to get Aligned well they got it aligned but wouldn't put tires on truck because try said they were too weather cracked so I had to drive home on the tires I drove they're on witch were 36/12.50/16.5 super swamper tsls truck drove decent little death wobble around 45-50 but nothing major got home swapped out tires started going down the road around 35mph truck is shimming unreal I mean I've had death wobble before but not this bad! It wouldn't come out of it would even do it at 60mph so I'm thinking of rotating the tires and if that didn't do it I was thinking of getting a New Trac bar and steering stabilizer but not sure what brand trac bar I should get and does it have to be a adjustable one since the truck has a 2" leveling kit?!
Any help would be greatly appreciated thankyou
MegaJamBox's Avatar
MegaJamBox
Truck is a 98 dodge 2500 v10 220k
Old May 1, 2013 | 10:32 AM
merc225hp's Avatar
merc225hp
Try a new set of tires, a tire shop refuzed to install them due to weather checking and you went home and installed them anyways? Not wize by any means.
Old May 1, 2013 | 10:37 AM
MegaJamBox's Avatar
MegaJamBox
Yes they refused to instal them because they have alittle weather cracking its nothing major just tire shop said they can't let it leave with a tire that's weather cracked.. But anyways back to the point it just started death wobbling with this set of tires so I'm trying to think if it's because the tires are so big or what...
Old May 1, 2013 | 10:46 AM
Or they aren't balanced.....
Old May 1, 2013 | 11:36 AM
MegaJamBox's Avatar
MegaJamBox
No they're balanced
Old May 1, 2013 | 11:47 AM
merc225hp's Avatar
merc225hp
Put somebody in the drivers seat, get them to turn the steering wheel side to side while you are under the front of the truck looking at all the tre's, trac-bar ends, replace whatever you find worn out. A longer track-bar is not needed for a 2" lift
Old May 1, 2013 | 11:51 AM
Thornloe Pride's Avatar
Thornloe Pride
It COULD even be a mixture of tires plus bad wheel bearing or U joint.
Old May 1, 2013 | 10:58 PM
AtomicDog's Avatar
AtomicDog
I upgraded to this model adjustable track bar, which required a custom bracket - very well made parts with no heim joint to go bad:
http://www.solidsteel.biz/datb.htm (Track Bar)
http://www.solidsteel.biz/tbk.htm (Bracket)
