Transmission
I have a 1998 Ram 1500 2WD 5.2L V8 magnum automatic. I am having two major problems with my transmission.
The largest and most recent problem is that, when I start the truck I can't put it in drive and take off, I have to put it in first then go, then move up to second, and then I can put it in drive and it all works fine until I get to a stop and I have to repeat the process all over again. I can't seem to keep it in drive and it work like I was working yesterday.
My second and longest problem is. After a while of not driving (long enough to have a cold engine) I will being driving and get up to about 20 MPH and all of a sudden the truck with start hitching and I have to let off the gas and then give it has again and it fines then it does the same thing at 30 MPH and after that its fine. Please can anybody help me?
1. You might just need to change the throttle postition sensor and/or the shift sensor
2. my ford actually did all of these and i changed the torque converter sensor and those 2 sensors i mentioned and i shifted like it was a fresh trans.....
hope this helps
hope this helps
What do you mean by this?
Is your fluid full and clean? Just to be sure you know, the fluid is checked with engine running and in neutral - not in park like most others.
See if fluid smells burned. It seems like direct clutch is not engaging when it should. Is TV cable adjusted correctly?
What is the shift sensor? These trannys so not have any such animal.
Trending Topics
Ok. I got a quest. Im new to this site so Barry with me. I got ab 03ram 1500 with 155k miles. My tranny shifts great when its cold but when is warms up dont shift rite. N when i have a load in the back slips a lil. I no i have to change the fluid but n e reccomdentations of what to add extra to help it out
i no about lucus but n e this g else? N how many quarts is ib the trans . I got a a 4.7l 4x4
