Starting Problems
Old May 7, 2013 | 09:08 PM
TheBigRedTruck's Avatar
TheBigRedTruck
I do have the I.O.D fuse removed because I don't want any accessories left on by accident or the custom alarm going off. Could this cause an intermittent starting problem?
Old May 8, 2013 | 12:00 PM
I would start by removing/inspecting ALL the fuses then.... make sure they are all getting a good connection.
Old May 8, 2013 | 12:58 PM
TheBigRedTruck
I checked all the fuses in the PDC. They weren't blown and had clean connections. How do I check the starter relay?
Old May 8, 2013 | 01:27 PM
Just swap it with another one. They are all pretty much the same in any event.
Old May 8, 2013 | 06:57 PM
TheBigRedTruck
Where is it though? I never replaced one or saw one lol
Old May 8, 2013 | 07:25 PM
In the PDC. (power distribution center, right behind the battery) They all should be labeled, if you still have your lid.
Old May 8, 2013 | 11:16 PM
TheBigRedTruck
The starter relay is there? I know the fuses are there.
Old May 8, 2013 | 11:53 PM
Matt Nickerson's Avatar
Matt Nickerson
Yeah...starter relay, fuel pump relay, horn relay, asd relay, etc. all there.
Old May 9, 2013 | 10:05 PM
TheBigRedTruck
ok i switched it with the a/c relay. wont know if this fixes the problem until it happens or doesn't happen again
Old May 23, 2013 | 10:33 PM
TheBigRedTruck
problem still happens. relay didnt work. Still getting a poping noise coming from the fuse box. could the PCM be bad?
