Oil Pump question
Old May 9, 2013 | 11:58 AM
Cnewt's Avatar
Cnewt
Default Oil Pump question
Ok, so I have been having tranny issues, and the trans is in the shop getting rebuilt. I figured while the truck was up on stands, being completely useless, I would tackle a an oil leak from the back of the motor. I replaced the rear main seal, and while I had the oil pump out, I primed it before I put it back in. The shaft felt good and tight and the pump would bubble and gurgle if I turned it the wrong way. My question is, should I have replaced the pump while I had it apart? Like I said the shaft felt tight, no play and dripped oil out the pick up when I turned the shaft with a screwdriver. The truck is a 1997 318 2wd with 132000 ish miles on it.
Old May 9, 2013 | 12:24 PM
chromed95's Avatar
chromed95
It'd been convenient to replace it when you were doing the rear main, but probably not immediately necessary.
Old May 9, 2013 | 12:26 PM
Cnewt's Avatar
Cnewt
Thanks.
Old May 9, 2013 | 12:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I would replace the pump.
