98 Dodge Noise
Old May 9, 2013 | 03:40 PM
kokotele's Avatar
kokotele
Default 98 Dodge Noise
Howdy,
Own a 98 Dodge 2500 Ram w/ 360 V8 4x4. Has a slight tick/knock when @ operating temp & lower oil press(20psi). When it's cold good pressure & no sound,120k on the engine. Is it a Rod or Oil pump? Wife pulls a 3 Horse trailer w/ it. Great source of information on this form. Thanks.
Old May 9, 2013 | 03:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Welcome to DF! I'll move your post to the 2nd gen Ram section.
Old May 9, 2013 | 03:56 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I would be willing to bet that the oil pickup screen is likely clogged up.
Welcome to DF.
Old May 9, 2013 | 08:05 PM
kokotele's Avatar
kokotele
Sorry about the wrong place and thanks for the replies. Sounds like an easy fix,lol. I'll follow up on the Oil pump and post the findings.
Old May 10, 2013 | 04:22 PM
zman17's Avatar
zman17
If you are going to pull the oil pan, replace the pump also. And you should replace the rear main seal while your in it. http://www.pavementsucks.com/tech/rearmain.php
Old May 10, 2013 | 08:18 PM
Wanna play guinea pig? Replace the oil pump with a high volume/high pressure unit. See what your pressure looks like at idle on a hot motor then.
Old May 11, 2013 | 09:29 AM
kokotele's Avatar
kokotele
Did some research on the board earlier and noted replacement of Rear Main. Not so sure about the Hi-volume pump w/ respects to clearence,cost,ect. I will post results from Oil press. test ect. at the end of next week.
