Plenium plate ?
Old May 11, 2013 | 02:52 PM
getdown78's Avatar
getdown78
Default Plenium plate ?
Is hughes performance the only place that sells the good intake plate kit or does somebody else make one ?
Old May 11, 2013 | 02:59 PM
Matt Nickerson's Avatar
Matt Nickerson
http://www.ebay.com/itm/DODGE-JEEP-ALUMINUM-PLENUM-PLATE-BELLY-PAN-318-360-5-2-5-9-MANIFOLD-REPAIR-KIT-/200922215893?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec7e5b5d5&vxp=mtr
Old May 11, 2013 | 03:02 PM
bwdakrt's Avatar
bwdakrt
The seller is a member of our group.
Old May 11, 2013 | 04:28 PM
aofarrell2's Avatar
aofarrell2
Buy the plate off of eBay. He's a good guy
Old May 11, 2013 | 07:47 PM
getdown78's Avatar
getdown78
Is it the same as hughes perf kit ?
Old May 11, 2013 | 08:19 PM
Matt Nickerson
The ebay one comes with the plate and plenum bolts, you supply the intake gasket set and intake bolts etc. They are the same thing, but the ebay one is cheaper.
Old May 11, 2013 | 08:53 PM
Gaius's Avatar
Gaius
You could also take yours to a laser cutter place and ask for a 3/16 6061-T6 plate cut to match the stock one.
Old May 12, 2013 | 10:45 AM
getdown78's Avatar
getdown78
But isn't the weak spot the stock type felpro gasket ? SO what good is a new plate if you still got to use a cheap gasket ?
Old May 12, 2013 | 11:05 AM
QuadCabLuv's Avatar
QuadCabLuv
No the weak point is the plate. The oe plate is steel and the manifold is aluminum, so they dont react to temperature changes the same way, causing the gap between the two to change.
Old May 12, 2013 | 11:11 AM
bwdakrt's Avatar
bwdakrt
I'm sure if you have done your research on the plenum you had to have seen where the problem is NOT the gasket but is the belly pan itself.
Let me explain this to you. The intake manifold is aluminum and the stock belly pan is stamped steel. They are 2 different types of material which means they will expand and contract at different rates which causes the gasket to blow out. Replacing the steel belly pan with an aluminum one eliminates the problem. Get it?
