Abs and brake light on! And no pedal
Hey everyone new here to the forum I have a 2001 1500 with a 5.9 with rear wheel abs I read a couple other threads about this problem but I'm not sure if anyone has actually posted a fix. See my problem is abs and brake light are always on and I have a squishy pedal, I've replaced the sensor in the rear end and my master cylinder and bleed brakes and still have the same problem someone said something about my rwal module could be bad so today I went out and pulled the cap off the valve and have fluid coming out when I push the pedal is this bad??? I'm assuming this is where I'm getting my air from and this is causing my back brakes not to work correct? If someone could help me out I'd be very happy! It's a little sketchy putting a 20 foot ski boat in the water with not all my brakes!
Ok thanks ill check them do they end up leaking? My fluid is really black and seams to have dropped a little over the past few weeks also I just checked and don't seem to hear my rear brakes working also could low rear shoes cause this or brake adjustment cause this? Thanks for the reply this is driving me xrazy
