dodge lean
Old May 18, 2013 | 12:02 PM
merc225hp's Avatar
merc225hp
The front coil springs are indeed side specific, the springs should be marked as such (all my lift coils are marked pass or drivers). Always replace springs in pairs or you will end up with a lean again. Yes your lean is being caused by the broken leaf pack.
Old May 18, 2013 | 04:15 PM
ramrookie92's Avatar
ramrookie92
Ok im getting a new drivers spring or passenger spring for free so maybe ill leave that aside till i find a set. And i just found two five leaf leaf springs from a truck with 126k at a parts place hundred a piece so ill throw those in and hope that helps. And ur sure i couldnt just put two factory passenger springs up front ied hace to get new ones ? Becuase im looking at a det of moog veriable rate springs for 120 shipped.
Old May 18, 2013 | 04:16 PM
ramrookie92
Set* sorry my key boards ****ty
Old May 18, 2013 | 04:45 PM
oxymoron29's Avatar
oxymoron29
My 2 cents: Just replaced a broken drivers side leaf in my truck, went to a spring shop and got a piece of stock with a similar curvature cut to size. Took apart the leaf pack, put new leaf in and truck sits level on both sides. Was going to replace the whole pack with one from the JY but I would've had to drop a full gas tank to access the front perch bolt. Cost me $30 and some time
Old Jun 1, 2013 | 03:17 PM
ramrookie92
Just doing a follow up went to a spring shop got the broken leaf replaced problem solved thank you guys.
