dodge lean
Old May 17, 2013 | 02:00 PM
ramrookie92's Avatar
ramrookie92
Default dodge lean
My dtivers side leans and inch in the back and a inch in the front. Im trying to find a new leaf becuase the one on the back is crack and missing a peice. And i already have a replacmeny junk yard front spring. Does any one know where i can get a cheap replacment. And i heard something about spring isolators? Should i bother fixjng this or juwt leave it be. Im also ganna check to make sure the springs are seated right. Any input helps thank you.
Old May 17, 2013 | 02:29 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
when replacing springs always do both rears at the same time same with the front
if you want to change springs to get rid of the lean swap the left to the right it will settle it flat quick enough
Old May 17, 2013 | 02:46 PM
Spell check?
Old May 17, 2013 | 02:47 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Go to the JY and snag a passenger side spring from another Ram.
Put it in place of your current drivers, boom, done.
Old May 17, 2013 | 03:20 PM
ramrookie92
I was told to replace in pairs so would just getting one junk yard spring for the front be bad ? And why should i use a passenger side spring as a replacment? Is it taller than the drivers side spring ?
Old May 17, 2013 | 03:24 PM
ramrookie92
Some one also said its my broken rear leaf causeing 90% of the lean
Old May 17, 2013 | 03:31 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
the springs are the same but the passenger side always has less sag
it will cause a little bit of the lean but you may as well make it 100% better not just 90%
Old May 17, 2013 | 03:56 PM
ramrookie92
I thought the springs were side specific
Old May 17, 2013 | 04:07 PM
dodge dude94
Nope. Not at all.
Old May 18, 2013 | 11:34 AM
ramrookie92
More input please
