How bad is this engine tick?
Old May 20, 2013 | 05:31 PM
Cali7312's Avatar
Cali7312
lifter.
Old May 22, 2013 | 06:47 PM
blk5oh's Avatar
blk5oh
So... I did an engine flush using gunk motor flush along with marvel mystery oil in it. Then I changed to gastrol gtx high mileage and replaced 1 qt with lucas oil stabilizer with motorcraft fl1a filter. Changed spark plugs to autolite 3923.
The ticking is still there, only after warmed up. I can hear it most during idle, probably because most quiet. But I can't hear it after 2k rpm, maybe ticking so fast I can't detect it? But as I slow down the rpm, I hear it a little but its not rhythmic, kinda like a fluttering tick.
Any other ideas I can try without pulling the intake and replacing the lifters?
She seems to run fine, except when I'm revving its a little rough between 2k and 3k. I'm going to try to replace the crankshaft position sensor, since I have a new one laying around.
Thanks for your input.
Old May 22, 2013 | 06:50 PM
blk5oh's Avatar
blk5oh
Also, how should the exhaust sound during idle, sometimes it sounds like its chugging.
Old May 23, 2013 | 10:24 AM
Might wanna pull the valve covers, retorque rocker bolts. Roll the motor over a couple times by hand, and see if everything is moving the way it should. Check for loose pushrods once you verify rocker bolts are tight.
