Damaged rear bearing hub race
Old May 19, 2013 | 11:07 AM
kburks's Avatar
kburks
Default Damaged rear bearing hub race
I'm stuck in Spartenburg SC need info on company that will cut off and replace damaged rear axle bearing hub on site without removing rear end housing from vehivle
KB
Old May 19, 2013 | 11:12 AM
The race can be pulled, and replaced. Just need to get it towed to a shop that will do it. It's really not that bad of a job.
Old May 19, 2013 | 12:40 PM
stewie01's Avatar
stewie01
However today is Sunday, you will be very hard pressed to find a shop open.
Old May 19, 2013 | 04:36 PM
kburks's Avatar
kburks
Default Rear wheel bearing hub race
I'm told that the race is part of the rear end housing and must be cut off and a replacement welded on or replace the entire rear end housing.
Old May 19, 2013 | 04:45 PM
kburks's Avatar
kburks
Old May 20, 2013 | 09:52 AM
AtomicDog's Avatar
AtomicDog
The rear in that truck has full-floating axles and the bearing races can be easily driven out and replaced, unless the truck has been driven for a very long time with a bad bearing..
Old May 20, 2013 | 10:52 AM
Atomic is correct. Full floating axle. There AREN'T any axle bearings. Axle is supported on the inner end by the carrier, on the outer end, it bolts in place. hub slides off the spindle, and both bearings are in the hub. Those are easily replaceable.
