2500 rpms no more
Old May 28, 2013 | 03:46 PM
byronpen's Avatar
byronpen
Default 2500 rpms no more
when my truck will not go above 2500 rpms. I did put Lucas tune up in before my trip could this be the problem? Transmission is replaced, complete tune up and front and top end all have be redone. This a new issue.
Old May 28, 2013 | 04:14 PM
Need more specifics. In gear when driving or sitting still in park or neutral?
Old May 28, 2013 | 04:18 PM
byronpen's Avatar
byronpen
When the truck is being driven. It acting like its starved for power.
Old May 28, 2013 | 04:28 PM
Have you checked the plenum? Any recent tune work done? Air filter clean?
Old May 28, 2013 | 04:31 PM
byronpen's Avatar
byronpen
PLease read the post.
Old May 28, 2013 | 05:50 PM
TheBigRedTruck's Avatar
TheBigRedTruck
I had the same problem. Clean and check the PCV system. It worked for me.
Old May 28, 2013 | 06:15 PM
byronpen's Avatar
byronpen
Pvc system?
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Did you ever replace your cat like you should have?
Old May 28, 2013 | 06:28 PM
byronpen's Avatar
byronpen
no I guess I will Drill a small hole before the cat, and see if that fixes the problem. if it dose I will replace the system Like I wanted
Old May 28, 2013 | 06:33 PM
dodge dude94
General rule of thumb: Blown plenum = clogged cat about a month or so later and a fouled 02 sensor.
FACT!
Granted the timelines vary.
