99 ram 1500 transmission problems
Old Jun 3, 2013 | 10:40 PM
big_daddy_proctor's Avatar
big_daddy_proctor
Default 99 ram 1500 transmission problems
Transmission it starting to slip between 1st and 2nd once im past 40 mph its fine and when i try to pass anyone it seems to hit neutral any ideas? Thanks.
Old Jun 4, 2013 | 08:17 AM
CSDavies26's Avatar
CSDavies26
the feeling of "hitting neutral" is the transmission slipping out of gear...the rpms will go up but the truck wont gain any speed. check your fluid level (engine on at running temp, on level ground, gear shift in neutral) and go from there. however, if i were you, I'd start looking for a rebuild shop
Old Jun 4, 2013 | 09:25 AM
Arde's Avatar
Arde
Change fluid and filter, adjust your bands.
